Jason Crawford told me about this so he gets full credit but I wanted to share.
I bought a 1" NPT brass check valve, an adjustable pressure switch and a 30 minute timer and installed to my filler pump and wired the pump through the switch. Coming off my pump is a close nipple, the check valve, another nipple, a T with a bushing in the top for the pressure switch to screw onto and then out to my filler hose. I adjusted the pressure down so that the normal flow pressure of the cold oil "almost" triggers the switch. Then when I'm filling, as I begin to let off the pump handle the pressure goes up a hair and shuts off power to the pump. Pull the handle again and pump comes on. The timer is so I can leave pump on and just set the timer on 30 minutes. Then if I forget to turn the pump off, I wont have to worry about a failed hose causing the pump to come back on and pump my tote dry in the floor.
Pics to come...
Pics to come...
