Here's my setup here in Colorado, this has been my configuration for maybe 8 years. I used to have a Dieselcraft OC100 centrifuge if any of you know that madness. 2 gal/min at 80psi and 160degrees....high opportunity for mess
ColoradoVegpsd gave me this absolute CF in bent and unusable form for all of the veg i've given him over the years.
Clean 275g tote on top - uses a separate oberdorfer and hose to fill the trucks
Dirty 275g tote on bottom - presettle
55gal heated induction tank - booger welds by me and ground down - heat to 175 deg, let settle
from induction/settle, it gravity feed through pipe heater to absolute CF that drains down into a 55g barrel flipped over. outlet to pump at bottom. takes about 6-7hours to do 45 gals
