I used a buddies sucker tank last weekend, it was awsome.
60 gal. compressor tank with a 1 1/2" inlet welded into the top and the outlet in the bottom.
We Pulled 27" of vacuum on it and drove to the dumpster (I was asked if i could take some out because it was too full) and sucked up 60 gal. of oil in 70 seconds... thats right, 60 gal. in 1 minute 10 seconds!
I literally was driving off after being there less than 3 minutes.
Went hom, put the hose on the discharge, held the other end over the prefilter barrel. Filled my compressor with 100 lbs of air and hooked the hose to the sucker tank and slowely opened the valve to let air in at the rate of only 1 psi and the oil began to flow rather quickely but not to quick. I maintained letting the air in at 1 psi and in just a few minutes the sucker was empty again. We made 3 trips over there and got 180 gal. Tested it for caustic of course but i also only sucked from the top and i didn't take more than the top half so any and all sediment would have been at the bottom of the sun soaked dumpster. The oil was clear and no sediment was found in my 200 micron screen after screening it.
I checked for caustic by adding water to a sample, mixed it up and let it settle. If there had been any lye, i would have turned to soap and not settled out but instead, it settled out completely in under 5 minutes and then i PH tested the water that settled. Of course i PH tested the tap water that i began with - tap water was PH 7 and oil water PH 7 also.
