Looking to buy some oil - PM me
  • Looking to buy some oil - PM me
    Hi all,
    I'm behind the eight ball in sourcing local waste fryer oil as all the restaurants in my town and the neighboring ones appear to already be supporting local greasers (yes, I need to find out who they are & swap experiences!). So, I want to purchase a couple of totes of oil to get a jump start until I can spread out my search to a wider area.
    If anyone on here is selling or knows of a reliable source in the NE, I'm perfectly happy to drive out to you/them/it and pick it up. I can work with filtered or unfiltered; do a tote exchange or bring my totes & fill them; whatever works.
    Also, I still have the 51-gallon tank for sale. I'd gladly trade that towards the purchase price if it would be of use to the recipient.
    FYI - I'm converting on Sunday! Can't wait to be burnin' grease!
    See my post about wvo for sale in Queens; he's just across the Triborough in Astoria
    http://www.dinofuelalternatives.com/...read.php?t=629
      Yup! Definitely plan on speaking with him - that was an awesome story & a great find; appreciate you sharing that on the forum!
      FYI - I PMed you a couple of questions about it yesterday.
        VTvegpower is half the distance to you then me,that might be more viable for you.He is located in the Richmond-Burlington VT area and has a great grease venture going up there.He bought my friends equipment(complete fitering,totes,barrels, and routes),and has a good business ethic.He is very polite and easy going.I would start there,if all else fails I do have oil,but at this time is unfiltered in 55 gallon drums,hope this helps........good luck this weekend.PS don't forget to read up on the PCM diode fix before your crammed under the dash,scrathing your head.......
          PM Sent.
          Good Luck!!
            Greasy, Thanks, man - I sent him a PM.
            Jack, Thank you also - PM received!
              How close are you to Scranton, PA? My source has a rest. in my town and Scranton. I get 25 gal a week from him. Pm me if you are interested.
                Thanks, Bill! I'm actually a couple hours from there, but there may be some folks on here that are closer - appreciate your response, man!
                  Big Thanks to VTVegiPower!
                  Solved the initial supply of oil problem, thanks to VTVegiPower (ie: Josh)!!
                  For the clean stuff, he filters and CFes, so there hain't nothin' there that hain't s'posed to be... reckon?
                  For the dirty stuff, he's got an saweet 500-gal sucker tank that moved that oil out and into my totes no time flat.
                  If ya'll need some erl, he's yer dude...
                    Thanks for the plug Eric
                    It was good to meet a couple fellow greasers and check out your Ex. U should post up those pics of our high-tech oil transfer system
                    Just let me know when you run out of oil and I'll swing by again Or let me know when Steve is ready to convert that Ex, that would be a fun project if I haven't done one by then.
                      Networking is the key for the survival of our cause,I practice this when ever possible.I am glad you two could help each other.........................greasy
