Looking for a supply in Norfolk VA...just installed the vegistroke, but found that I am moving in a couple of months. Hard to develop a relationship for WVO for only 3 months without pissing somone off.
WVO in VA
I can probably share a little oil. You need about 160 gallons in all then.... I don't think I have that much, but I will check my supply and get back with you. The oil will be filtered and in the cubies that it came in. In each cubie there is about 1 gallon of the PHO, but it is settled to the bottom, so it can easily be discarded if you don't like to use it. Where you moving to?Last edited by Hooter; 11-03-2008, 12:12 PM.
