There is alot of talk on other sites about running this in your primary tank; anyone here ever do it? What were your results?
Waste Motor Oil
Originally posted by waytallwhitey View PostThere is alot of talk on other sites about running this in your primary tank; anyone here ever do it? What were your results?
I also don't use enough engine oil or tranny fluid to make it worth the risk.Vegistrokin since 08/23/08
Another vote for not going to go there....too much to chance and it just wouldn't be worth the risk to me.Greasin & Grinin
Originally posted by tacit_k View PostWaste fryer oil has glycerol and stuff, waste engine oil and tranny fluid has metal bits if you want to spray shards of metal through your expensive injectors fine by me. As for me I'll stick with WVO2001 F250 Crew Cab V3 Conversion
It would smell like the most pollutive truck on this web forum2000 7.3X V3 So much fun,so little time,Support small Oil,burn WVO,Free and greasy down the road I go!!!!!!!!!!completely self sufficient and proud of it. (Wood furnace.....X.......solar pontoon....solarsheat twins this summer.....I don't Know much.......I'm just a hillbilly with too many guns..............
How about centrifuging for reuse,25% used to 75% new and cut the rest with WVO as Bar and chain oil?I believe the more oil we re use instead of burning will result in less demand for foreign oil.I currently have been using above mixture for bar and chain oil for 2 years with no problems.If you cut with kero you could use either as 2 cycle oil.Spend awile in front of a ASTM chart of petroleum products and you will see with filtration,just how much you can reuse............greasy2000 7.3X V3 So much fun,so little time,Support small Oil,burn WVO,Free and greasy down the road I go!!!!!!!!!!completely self sufficient and proud of it. (Wood furnace.....X.......solar pontoon....solarsheat twins this summer.....I don't Know much.......I'm just a hillbilly with too many guns..............
Originally posted by CHenry View PostI can only imagine it would smell just like our old lawnboy mower...Greasin & Grinin
