More specifically, what fittings did you use to adapt the 2" fitting on the tote down to a more useable 3/4" or 1" line?
My tote has the standard (I believe) 2" fitting on it and I need to get it down to 3/4" clear tubing if possible. I picked up a 2" PVC female adaptor and a reducer to bring it down to 3/4" (also in PVC), but seems like I've read that folks don't recommend PVC in this application.
Any truth to that? Will the PVC work okay for reducing it down? If not, anyone know if they make metal (black pipe) reducer fittings in that size?
I'd be more hesitant screwing a metal reducer fittings on those plastic threads I believe. Seems like it'd be awful easy to strip them off.
Thanks in advance!
Thanks in advance!
