My Harbor Freight cheapo pump ($29.99) may be on its last leg. Doesn't seem to like the 20 degree weather much. Looking for a replacement/backup for my still. What do you guys like? My understanding is that the Northern Tool pumps are quite a bit better even though they look very similiar. I was also considering some of the Redline pumps which are quite a bit more $. Any thoughts would be appreciated.
Replacement pump for still??????
Originally posted by CHenry View PostNortherntools tuthill pumps are good.
http://www.northerntool.com/webapp/w...7963_200347963
Originally posted by HORSEMOVER View Post
That pump is fine for filling the tank with and only running for a short length of time but i have smelled what seemed like elec. burning comming from that little POS after running 10 minutes to fill the truck so i would NOT use it on my still under pressure and for longer cycle times. This pump i'm told doesn' like pressure.
Its a POS just the same as the harbor freigh job but it has its place in my system for now.
Heres another poption i like...I think i will try the redline 2000DD when I need another pump...its a little more $$ but not much and i almost bet its a quiet pump with some real guts.
http://redlinepumps.com/lowcostpumpsmp2000dd.html
Originally posted by CHenry View PostHeres another poption i like...I think i will try the redline 2000DD when I need another pump...its a little more $$ but not much and i almost bet its a quiet pump with some real guts.
Originally posted by HORSEMOVER View PostThats the one I was looking at. Actually I think you turned me on to that Redline one awhile back but I opted for the POS to see how it would work.
As i said, it works fine for movign oil from tote to tank but i wouldn't trust it to run long under pressure for an hour at a time with my still.
My tuthill pump has moved several thousand gallons and it keeps on going...and its fast, real fast but its also loud and annoying. The redline is the next one on my shopping list i think.
Talked to the guys at Redline today and they said the MP2000 RSG is the cats azz for pumping cold oil. It better be for $499. Below is a link
Originally posted by CHenry View Posthere it is, this is basically what i have only its a different model number and its a better pump than mine...this one has a 30 min. duty cycle and mine does not. Mine is kinda loud and i dont know about this one.
Without going and checking the model number, I'm pretty sure this is the one I have. It's a good pump and it's fast, but it is LOUD....haha.Greasin & Grinin
Originally posted by HORSEMOVER View PostTalked to the guys at Redline today and they said the MP2000 RSG is the cats azz for pumping cold oil. It better be for $499. Below is a link
Maybe the motor haas more horsies but the pump unit looks identicle. At half the price i would use the 225.00 model. If your using this on your still, your oil should be over 90*f when your filtering and i should flow just fine. Even if you were pumping cold oil, it should be fine. And you can always pick up a larger motor (this one is 1/3 HP) to put on it cheap.
Same exact unit but has some kind of gear reduction system that is supposed to help not burning out the motor when pumping cold oil. I usually filter right around 100 - 110 degrees so no problems there just moving the oil into the hwt when it is 10 degrees in the barn. I guess I could always pick up a band heater for the settling drum.
Originally posted by HORSEMOVER View PostSame exact unit but has some kind of gear reduction system that is supposed to help not burning out the motor when pumping cold oil. I usually filter right around 100 - 110 degrees so no problems there just moving the oil into the hwt when it is 10 degrees in the barn. I guess I could always pick up a band heater for the settling drum.
I have seen guys drop a bucker heater in there drums for this purpose. This pump would still move the oil at 10* probably, It would just be slow and you might want to monitor how hot its getting and turn it off for a breather if it gets warm enough you can't hold your hand on it. Even if it sowed to 5 gpm, it would only take 10 minutes to move oil into the HWH and i wouldn't think that is long enough to burn it up. Is your oil fitration still in a room that actually gets that cold like a barn or something? My new shop hasn't gotten colder than 50* yetYou can also install a HWH element into the barrel in the lower 2/3rds of the barrel, just don't forget and leave it on more than a couple hours.
you might still try the northern tool blue pump like mine, i pumped oil the other day that was cloudy - had alot of animal fat in it and it was the consistancy of gravy and it pumped it fine. took about 10 minutes to pump 50 gallons on a 20 foot hose and about 5 feet of lift. And you can still heat your barrel to help speed this process.
Has your other pump quit completely or are you just thinking it will soon?
