^^^^ That pretty much sums up where I am right now.
I picked up some oil a few weeks ago that I'm pretty sure was contaminated with something. Its smelled pretty bad but at the time, I attributed it to whatever was cooked in the oil. I'm running a Frybrid still, by the way.
Throwing caution to the wind, I filled my prefilter barrel and then pumped into my water heater. Heated at 140 degrees for 4 hours and let it sit for 24 hours. I drained 4 gallons and performed a hot pan test. The oil failed. I drained another 4 gallons and did another HPT -- failed again. I let the oil sit for another 24 hours and performed another HPT. This failed too. I repeated the draining and testing until I was out of oil. The oil failed the HPT every time. I'm not talking a few bubbles -- I'm talking pops and crackles.
So I got rid of all that oil, drained and cleaned my prefilter barrel with water only, and pushed about 30 gallons of oil through the water heater. Drained all that off and everything sat for a week without any oil or water in it. Prefilter barrel was bone dry but the lines on my still had some water in them. I figured that would settle out in my next batch.
On Sunday I picked up some oil from a different source and pumped it into my water heater via the prefilter barrel. Heated again, settle for 24 hours, and performed the HPT after draining 4 gallons. More pops and crackles. Drained more, tested again. Failure. Repeated until all the oil was out of the water heater. Oil failed the HPT with pops and crackles every time.
So I tested a couple of tablespoons off the top of the 250 gallon tote that is holding the oil waiting to get processed. It was right on the borderline of passing.
Any idea what's going on and how to fix it?
Thanks in advance for the replies....
--Snake
