This is a subject that keeps coming up due to the importants of knowing if one has good clean, DRY OIL, OR NOT.When I first met Jayson I owned a Dodge PU with the cummins engine. This truck ended up becoming the first Dodge to have a proto type vegi kit install.
I was very lucky to have had one scource for my WVO. I would pick it up once a week 10 to 15 gallons and this oil was almost water free.
Really!! All I did was filter thru a 50 Micron sock & then a 5mic sock filter.I would due the HPT and find almost always NO Spitting NO BUBBLES.
Now: I have a Ford F350 with 7.3L Powerstroke and Jayson installed the latest greatest system on the planet for this rig.
Problem: I had to find another scource for my WVO and this new WVO has become difficult to get the water out of.
I heat my barrel to 120' F using a combo of a submersable heating element & then a heat belt. After getting oil heated to the 120'F I mix the oil up and then continue heating with the belt ( Straped aorund outside of barrel).After cooldown I test w the HPT methad. I continue to get these little bubbles ( About 15 per pan full ).It never splatters but still I get those little tiny bubbles. HELP !! anybody got some thoughts regarding whats going on??? This is a long one so I will end now, But I thank you in advance. Thank you, Regards: W Mackenzie The MacKenzie river Man !!
