broken power mirrors?
  • broken power mirrors?
    Power mirrors not working right? Its probably just the switch on door panel. New switch costs about $16 at powerstrokeshop.com and takes about 30 seconds to swap out. Many people assume the motors are bad or something...
    Cheers!
    Jason, I take it you had one die on you?
      Yep. Since then I have 'fixed' several more for people who also thought something more expensive was wrong. They must fail pretty often...
        Every time I crack the window a bit, if it's precipitating, it drops right on that dang switch along with the window switches! Vent shades maybe?
        2000 F250 7.3 PSD-Revtech lift, big tires, Edge Juice w/Attitude, cold air intake, big fuel bill!
        Have WVO Source now, just need to pick and install system! Just discovered DFA. Sweet.
          Originally posted by mrclean1776 View Post
          Vent shades maybe?
          I can't live without them!!
            Not to hijack but does that have anything to do with the turn signal in the mirror not working as well?
            2000 Excursion Limited 4X4 w/ V3
            15k miles and counting
              hehehe, not to ignore your question (I just didn't see it!!)....
              I doubt it, this lil switch just controls the mirror adjustment. None of my junk is fancy enough to have lites on the mirrors - lol, so I can't help much!
              Thats a GREAT question for the PSD gurus at www.ford-trucks.com - just scroll down to the appropriate section (7.3 or 6.0 or Excursion, Van, etc). There are 10's of 1000's of members there - its almost a sure bet one of them knows whats wrong!!
                My switch failed last year, i took it out, cleaned the contacts and it works like new again.
                  Thanks for pointing me in the right direction. May have to pick up some vent shades as well.
