Ok, i have the fill problem solved as well as then slight leak from the breather so onto my nxt thing to get dialed in. How the heck do i fill the tank when i am out of the road. Would some sort of a funnel with a bend in it work best or what do you guys use. I will most likely fill up cubies or perhaps use a 5 gallon gas can.
How to fill RDS tank from cubies while on the road
2002 Excursion Limited Ultimate 7.3 PSD. DP Tuner NS, Stock, 1100 HI, 60t, 80e, 120r, 140a. 4" MBRP Exhaust. AFE stage 2 w/ Pro Guard Intake. 35" Toyo M/T & 20" AR Thug w/ Teflon Coating. Bilsteins. Vegistroke V3 VO System. 203* Therm. Pilot Bi-Xenon Head & Fog Lights. Foil DeleteTags: None
I think most guys that use cubies have modified one of the lids so that they can attach a hose to the lid.
If I was to give it a shot, I'd just drill a hole slightly larger than your standard 3/4" galvanized hose adaptor, stick the threaded end of the adaptor through the lid and secure it on both sides of the lid with a 3/4" NPT nut and viton rubber washer. Slap a hose on it and let it go. Might have to punch a breather hole in the cube though so it would drain.Greasin & Grinin
Originally posted by Marv View PostMight have to punch a breather hole in the cube though so it would drain.-Drew
What MArv explained works great...these libs are however kinda brittle and after a while will crack if you bend that hose alot putting stress on the cap so try to use a real flexible hose and make it like 2' long so it will be more plyable.
Originally posted by Clay Henry View PostWhat MArv explained works great...these libs are however kinda brittle and after a while will crack if you bend that hose alot putting stress on the cap so try to use a real flexible hose and make it like 2' long so it will be more plyable.2002 Excursion Limited Ultimate 7.3 PSD. DP Tuner NS, Stock, 1100 HI, 60t, 80e, 120r, 140a. 4" MBRP Exhaust. AFE stage 2 w/ Pro Guard Intake. 35" Toyo M/T & 20" AR Thug w/ Teflon Coating. Bilsteins. Vegistroke V3 VO System. 203* Therm. Pilot Bi-Xenon Head & Fog Lights. Foil Delete
Here's my method - 18V DeWalt screwgun and a drill pump - a washing machine hose threads onto my pump - cut hose in half, with piece threaded on each end of pump - a 10" long piece of metal tubing clamped in the suction end of hose (works good for sucking out the last tbsp in the container - when you're done, slide exit side hose onto suction tube - no mess, no heavy lifting... There's a pic in my album on this site.
I'm guessing it takes about 2 minutes to pump out a 5-gal jug, though it might be a little less if it's warm. Oh, and drill pump I picked up at the local hardware store for $8, and washing machine hose at the dump off an old machine - $0. Steel tube was a scrap piece of large brake line - 3/8"?Last edited by Danbeck; 06-15-2009, 05:27 PM.Ma always said to eat my vegetables...
2000 Excursion w/7.3 turbo and V2, w/Superchips;
2000 F250 w/7.3 turbo and V3, w/Superchips;
9245 gals WVO burned so far. All filtered with denim pantlegs...
I really like the drill idea. I will probably go that route in the future. But in the meantime, I found that the lid off of a Rotella 2.5 gallon jug is the same size and treads as the cubies, but it is made of thicker, more flexible plastic. I drilled a hole and force threaded a 1" treaded nipple into the higher quality cap, installed an 18" long by 1" black rubber hose, and the cubies dump in less than a minute after you cut the bottom. I recently went on a 1000 mile round trip to Florida, bringing 6 cubies with me. I dumped them very easily with this set up, without much or any mess (just a small dribble from one). I managed to get 17.5 mpg or thereabouts. I ran out of veggie oil about 15 miles from home. But it didn't take but 30 gallons to fill it up again. I wish I could get use from the entire 40 gallon tank!
Originally posted by Jack_Toepfer View PostAn Arizona tea jug screws into the filler, make a funnel out of it.2002 Excursion Limited Ultimate 7.3 PSD. DP Tuner NS, Stock, 1100 HI, 60t, 80e, 120r, 140a. 4" MBRP Exhaust. AFE stage 2 w/ Pro Guard Intake. 35" Toyo M/T & 20" AR Thug w/ Teflon Coating. Bilsteins. Vegistroke V3 VO System. 203* Therm. Pilot Bi-Xenon Head & Fog Lights. Foil Delete
Originally posted by Jack_Toepfer View PostThe one thing that I thought of after I was pouring oil through it was that it will burp from not getting air into the tank... so put a straw or something into the tank so it can breathe.2002 Excursion Limited Ultimate 7.3 PSD. DP Tuner NS, Stock, 1100 HI, 60t, 80e, 120r, 140a. 4" MBRP Exhaust. AFE stage 2 w/ Pro Guard Intake. 35" Toyo M/T & 20" AR Thug w/ Teflon Coating. Bilsteins. Vegistroke V3 VO System. 203* Therm. Pilot Bi-Xenon Head & Fog Lights. Foil Delete
