Tank install directions and/or tank spec diagram
  • Tank install directions and/or tank spec diagram
    Does anyone have the tank install directions?? I am planning to drop the tank to perform some upgrades. I had the Ex install done by tanton (he is out of courntry right now). I want to drop the tank and tie together the coolant lines to be able to drive on diesel while work being done......
    Work to do:
    1. Get tubing to run off the fuel pickup to reach the bottom of the tank.
    2. Get fuel gauge that is accurate.
    3. Have a drain plug Tigged in the bottom of the tank.
    4. run a breather extension towards the front of the ex.
    If anyone has the tank install plans and any advice on the following upgrades, you can pm or pm me
    Thanks
    Check my thread for the pickup, it is working great now. I have had the thing way low on oil and it still works good. Only thing I would add to your list is a set of straps like wilson has just in case.
