P1249
  • P1249
    Been getting this code under hard accel (merging on highway),and am leary.Anyone else get this before,and do I have to worry about turbo damage?Stock except Walker BTM and AIS intake,waiting to put on the sixgun with pyro before its fixed...........................
    It's an over boost code- I have had mine do it under hard accel too, it's generic and hard to diagnose. Could be the chip but I would also check the vacuum line to the wastegate. I had a vac boost fooler, took it off and haven't seen it since but I haven't stuck my foot in it lately either.
      No chips yet
      I have a Banks Sixgun P/N 66513 2 inch pod tuner +62 hp,and +163FT LBs TQ,But its still in the box waiting for this issue to be resolved.This unit does have a EGT limiter,and boost limiter built in.Would installing this unit actually help to control P1249 from burning my retna every time I stand on that skinny pedal?I am building my truck graciously and putting down a good foundation(my last truck was a 275HP 525LB 12V gen one dodge cummins).I started with the best function and performance wth a AIS and Walker BTM.I am putting a six-gun with gauges to monitor everything safely.Will this code thing keep plagueing from here on out?Thanks for your info in advance....................
        I get the same code everytime I plant the right foot, but a few seconds after I release the light goes out.
          No Chip the wastegate must not be operating properly, it's not uncommon to throw that code running a chip something you have to live with (unless you have a tune or device to eliminate it) but the factory tune should not be throwing it.
            1249 *
            WG
            Waste-gate failure steady state
            GND short, pluged hose/port, solenoid, actuator
            Sounds like an overboost code from your chip. You might want to try using a boost fooler.
            1999.5 F-250
            180CC Singles
            Diesel Innovations 5 Position Chip
            Home Brewed WVO System 40,000 miles and counting
