What is your veg fuel pressure when it's time to change the filter?
  • What is your veg fuel pressure when it's time to change the filter?
    I would like to know on average what your fuel pressure gauge is reading when it's time to change the veg filter.
    2002 Excursion Limited Ultimate 7.3 PSD. DP Tuner NS, Stock, 1100 HI, 60t, 80e, 120r, 140a. 4" MBRP Exhaust. AFE stage 2 w/ Pro Guard Intake. 35" Toyo M/T & 20" AR Thug w/ Teflon Coating. Bilsteins. Vegistroke V3 VO System. 203* Therm. Pilot Bi-Xenon Head & Fog Lights. Foil Delete
    While I don't currently have a pressure gauge, I have checked my pressure manually once the light starts flashing.
    If I recall correctly, once the light starts flashing, I'm usually down in the 50-55psi range. Been a while since I've checked it though, so I could be off a bit.
      Having a brand new system I want to make sure I ask anything and everything I can so there are no surprises.
        Youll know when its time to change, when that light goes off under acceleration, its time. That will occure around 55-60 psi.
