So I got new Isspro gauges......and they look sharp...... but now I have a miss (rough idle low power)
2002 F250 basically stock- NO chip
I did a cc test with my scangauge and it gave me a P0284 code.
I tried a buzz test and it sounded right, but scangauge said "cannot complete test"
Im very close to 200,000 miles on what I believe are the stock injectors (I got the truck with 120,000)
I was hoping to make it to 250,000!!
Before we messed with the truck to install the gauge, the truck was running great though.
It started nice and ran strong/ idled smooth right away even on cold mornings.
Now after the gauge install....it idles obviously rough and is very low on power....
Is it possible the injector just went bad? and THAT bad?
I had to get fuel injectors replaced in my 550 before and I could gradually feel the truck getting worse, not isntantly like this. The 550 would run bad cold, then warm up and run better, when it had bad injectors too....
I searched and found someone who had the same problem and a black cps fixed it... (I have the grey recall one)
Im not holding my breath on that one though....
I have a friend with a snap-on scanner........ How can we determine if it really is the injector or something else?
Cylinder 8 contribution/balance fault Power cylinder, valve train or injector problem, circuit
