First problem with my V3
  • First problem with my V3
    Hey Guys and Gals. Haven't been on the site for quite awhile and Life has been good.
    Yesterday as I was driving, I started hearing a noise from my truck. At a red light, I rolled down my window and it was pretty loud. the noise was coming from my module.
    When I got home, I shut down the engine, turned the key on and then put the switch in manual to have the system come on.
    The pump is making a sotra grinding sound. Like a a/c compressor when it is bypasing freon. I noticed a couple of days ago that my diesel and veg gague have been dropping pretty much evenly. Meaning that I had used half a tank of veg and almost half a tank of diesel. I knew that something wasn't quite right. I even installed a new filter to see if it had any effect. No effect.
    So, I think my pump is going out.
    anyone else have pump problems???
    Wow, a pump going out already is unusual. I have not heard of anyone having a failed pump so soon. How many miles have you got on it?
      Hey Clay
      I have about 15,000 miles on it now. I installed the kit on March 15, 2008.
      So it is almost a year old now
        Been there done that
        Elvia our systems were installed within 3 days of each other and my pump failed in may 08,with 7,000 miles on it.I believe we had a "bad" batch of fass pumps(My cousin had a FASS pump fail in a different application (DRAG TRUCK duel fass set-up),that pump was shipped about the same time thru FASS and seemed to have same "inerds" when in disected..........NOT a DFA flaw,definately machining from FASS on the seal in housing.On mine WVO got into the electric"BRUSHES" and it made a "marbles in the blender sound".Have no fear it isn't the first to go just not common place...........PM with Q's on mine...........greasy
          Awe man thats a bummer to bad that those guys from DFA won't talk to you unless you wallets out!!! :chuckles::chuckles::chuckles: Just kidding, give me a call Elvia!
