This is pretty much an annual event that every year with cold weather. Some start to experiance Hard Starts, excessive smoking when cold, running rough once started, or simply just hard to start. For those of you new to diesels, Most all of them use Glow plugs to help the engine start when cold. Glow plugs are similar in shape to a Spark Plug, and are little heaters that mount in the head and just barely stick into the combustion chamber.
Diesels operate off of compression and heat unlike a gasoline engine that requires spark. Standard Diesel has an autoignition point of 410f. That means the air in the cylinder needs to achieve at least 410 before the engine will start. With a cold engine all the heat can be easily taken out of the air preventing autoignition from ever being achieved. With enough cranking eventually heat will start to build up and it will start. The glow plugs provide a heat source for the diesel to ignite until the cylinder walls build enough heat for the engine to sustain combustion on its own. And vegetable oil has an even higher ignition point that will vary based on type. So even a light mixture of Diesel and VO will affect the ignition temperature of the fuel. Without a properly maintained glow plug system, this can also cause hard start issues. NONE OF THIS WILL DAMAGE THE ENGINE!! Just simply the nature of diesels and cold weather.
I have put together some information on what the Glow plug system does in the following posts as written in the Ford Service Manuals, and will also revisit adjustment procedures for the Vegistroke timer cards. Long story short, to ensure a trouble free Winter, Check your Glow Plug system and purge timers. I have countless times troubleshot a hard starting truck to a bad Glow Plug System.
