We did the conversion this weekend; fortunately for me my buddy Frazier has some experience with this conversion having done an older one on his F350 a couple of years ago, and my buddy Tom is a wizard with automotive electronics. The conversion was installed in ~ 10 hours give or take a couple of hours for various breaks.
Sunday I topped off the tank with filtered wvo and took 'er out for a cruise. Less that 3 miles from home the green light came on letting me know we had switched to wvo and all was good! No problems at all, not so much as a hiccup. I filled the diesel tank ($100.00 even! Ouch!) just so I could see how far I can get on the diesel. I put on about 70 miles yesterday and 172 today; that diesel fuel gauge hasn't moved! I've burned about between 1/2 and 3/4 of a tank of wvo.
I am one happy dude!
Now for some gripes -
The studs on the back of the fuel gauge were too long to allow the gauge to fit properly inside the pod; not a real big deal, a quick minute with a disc cutter and all was good, but for the $$$ it should have fit coreectly right out of the box
If you have a plastic bed liner make sure you pre-fit the tank BEFORE you cut the hole! The liner does not follow the contour of the bed too closely so the hole won't be where you think it will be when you cut it; consequently the rear tab of the tank had to be trimmed to clear the hole. This is no one's fault but my own, but I just thought I'd throw the warning out there to pre-fit the tank before you cut the hole!
My buddy Tom that handled the wiring says a schematic would have made it easier for him; this is not my gripe, I'm just passing this along for future installers
And finally, that green light is TOO BRIGHT! This morning I had to stop and tape a piece of paper over it to cut down on the glare from it; but it sure is nice to see it lit up!
All in all it was a painless install and I could not be happier with it! Than k you James and Jason and everyone here who offered advice and assistance!
