Cant Finish Install- wrong fitting?
  • Cant Finish Install- wrong fitting?
    On the T fitting for wvo under the hood.....
    All 3 hoses should be the same size at the T, right?
    The T has all the same size threads, but one of ends on the hose is WAY to big.
    Everything else fits where it should.
    Ive been to NAPA, Pep Boys, and Autozone.....Nobody has an adapter to make it fit.
    The only option I can see is to wait till tomorrow and go to Amazon hose to have the wrong size fitting cut off and install the right one?
    Anybody have any ideas?
    -Shawn Collister-
    Straight outta Wimauma
    Tampa- You likely have the wrong fitting. This is not the first time this has come up. Our supplir apparently slipped us some wrong hoses. So come Monday we will now go through every hose we have to make sure they are all correct. There are two ways we can handle this. We can Overnight you the correct hose tomorrow, or you can find a local hydraulic supply store and get a #8 to #6 reducer. Sorry about the troubles.
      Im going to call you guys this morning (Monday)
      **edit** problem solved Thanks Jason
      -Shawn Collister-
        are you in Tampa, Florida ?
          Yesser I am....... Tampa/Riverview
          -Shawn Collister-
            we got to get together.
              I'm in Riverview and Stroker and I already know each other.
              --Snake
              2005 F-250 Harley Davidson Edition with a few mods
              60k on veggie oil and counting
