I stopped at Twin Tire shop and asked how much a brake job cost for my 350 dually today. I was shocked when they told me 400-500 dollars. Whats a brake job cost in your town?
Free....cause I do my own! Lol...
Out of curiosity, the duallys have disks in the rear right? I assumed they did, but I've never checked one out up close. I can't imagine they'd be any more difficult than your standard brake job.
Could be worse price out a Ex,I just had frt and rear done I believe it was $800
4 wheel disc and if its 4x4, theres a little more work getting the front roters off to turn. If they don't need turned, i think you should be looking at around 250 including labor...think thats what I paid my tech buddy to do it in his driveway last year.
I usually do it myself but he was doing my ball joints and called me to tell me the brakes were needing done and i just said do it.
$250 is about what I thought it would cost, give or take. they said because it was a f350 I don't really see the difference between a 250 and 350 to warrant another 150.00
hmmm...not sure about that. I would think it would be the same.
I think my O'Rielly lifetime warranty rotors were $150ish? and IIRC NAPA loaded HD calipers were a little over $200. Rear loaded calipers (NAPA) were $180ish. Brake hoses were high too...
Alot of folks run Hawk pads and there are some HIGH $$$ upgraded calipers and rotors available!!
Don't bother turning these rotors, they'll warp again first time they get hot. If they don't shake the steering wheel when ya stop - ROLL ON! My rear rotors are STOCK w/260k miles on'em.
I'd say the job can easily be done on a Sat afternoon by anyone w/a socket set and the abilty to take the tires off. 2-3 beer job, no problem!
As you can see, these aren't the cheapest parts and shop labor is expensive, period. Not thinking the price quoted is out of line if the parts are quality and the tech is good.
2001 F350 XLT 4x4, dually flatbed. 6637 air filter, single-shot injectors, straight-piped, BTS tunes, 200 gal main VO tank - 180k greasy miles 2000 Excursion Limited 4x4. V3, AIS intake, BTS trans & tunes - 120k VO miles veggiegarage.com authorized installer
Really?
My fronts are shaking a lil bit right now.....I was gonna have my friend turn em... but maybe Ill just pick up some new ones today....
-Shawn Collister-
Straight outta Wimauma
Really?
Yep. If it costs ya nothing, you can try it - but I think you'll be buying rotors before long anyway!
The biggest issue is "They don't build'em like they used to." OEM's gain little by selling parts that can be 're-used'. They (and the aftermarket) make much more selling that huge hunk of steel than they did 'back in the day' when we could turn rotors.... bastards!
Such good fedback
Actually, my brakes are pretty good. Its just that I had the parking brake on a couple of times and drove off. So my parking brake has nothing left to it. If I park on a incline, it will just roll down with the brake on. so, I just leave it in frist all the time when parked. Good thing we don't have any hills here in south Louisiana.
I don't have any shakes either. I have 194,000 on the truck now. I bought it with 180,000. I looked around and can not find an way to adjust the parking brake. Hows it done?
Such good fedback
Star wheel adjuster just like yer old-fashioned drum brakes. They are drum brakes btw, its a drum-in-hat set-up - drums for e-brake inside 'hub' of rear rotors. They are NOT self-adjusting, so you're probably in luck!
If you find they will not adjust, upon disassembly you may fnd the crappy pot-metal the star wheels are made from have stripped threads. Don't buy more crap from Ford, make your own adjusters by cutting 'slots' for a screwdriver/adjuster tool to grab in a regular nut. :chuckles:
I have pics somewhere if this didn't make sense!
This 'trick' is a DFA-forum exclusive. I don't think I've ever shared it anywhere before! :cheers:
