i just had my system put in and the check engine light has been on sine the installation and wont go off.....any suggestions??
check engine light?
check engine light
one of your PCM diode wires is wrong,this happened on the GreasyX,nothing to worry about.Search past threads on this,Particularly The Diesel stop(alternative energy).This was before this sites inseption I believe 3-08.grease out2000 7.3X V3 So much fun,so little time,Support small Oil,burn WVO,Free and greasy down the road I go!!!!!!!!!!completely self sufficient and proud of it. (Wood furnace.....X.......solar pontoon....solarsheat twins this summer.....I don't Know much.......I'm just a hillbilly with too many guns..............
Mine was on after install because of a vacuum line that was left off when it was started after install. Disconnect the battery cables and it should be gone when you reconnect them. Otherwise, go to Autozone and they will reset it for you. God Luck.2001 Ex 7.3 With V3 and 40 Gallon Tank
check engine light?
Mine has been on ever since the install. I cleared it out several times and have figured out that it only occurs when the turbo timer/system flush occurs. I get this waste gate error code and something else (cannot remember).
Now, I just operate the system manually. Much easier than clearing that code every time.
