grounding
  • grounding
    what/where is the best way to ground the small eyelet on the fuel tank harness and the small eyelet on the main module harness? thanks
    I used the self tapping screw that came with the kit and screwed it into the body from underneath. On my 2001, right across from where the V3 is mounted, there were some tunnels[?] of sheet metal. I ran my excess wiring in there and also screwed the grounds there.
      thats where I went too. There are going to be 3 grounds going there.
        I'd suggest cutting it off and crimping a larger connector on there.
        -Drew
          Ditto - me too.
