coolant lines
  • coolant lines
    Just started my Vegistroke install. i have the fuel system done, tank mounted and i am ready to install the coolant lines to my heated tank. Does the kit come with T's for the coolant lines? The instructions say to put a T in both coolant lines under the hood but i cannot find them in my kit. There is no picture in the instructions for this part so any suggestions would be helpful. thanks.
    You should have 2 t's with your kit. mine are black. and they have barbed fittings on them. they are to fit in your coolant lines.
      Are they plastic or metal material? If possible could you post a picture of how you T'd them off? thanks for the help
        I can't post a picture because mine are installed. Mine were black plastic T'S. They were in the same bag as the zip ties and dino decals. I saw the same fittigs at Auto Zone for $9.99.
          Mine were not included either. I suggest calling and having them sent to you, or as I did, I went out and got some of my own so I could get the job done.
            Mine had them, dark grey kinda, not sure what bag they were in.
