the past few days i have noticed that the truck would surge as if it was running out of fuel or getting to much fuel or something. i really do not know. i figured i could explain it to you guys and maybe figure it out.
it will idle rough at start up, and at a few min. after start up the truck will rev. up for a few seconds and then return to normal. it may do this two to three times and then stop. then down the road a ways (lets say 5miles) it will do it again, but not rev up as much (maybe becaus it is in drive). then after i get to work it will not do it (work is about 30 miles from the house). it has not given any codes yet.
are these symptoms of a injector or a glow plug going bad?
note: i have been off of WVO for about 3 days, and in the process of running some diesel kleen thru the diesel side of the system.
any ideas would be great.
thanks
chris
thanks
chris
