ERG Val 0404 1335 codes
  • ERG Val 0404 1335 codes
    Has anyone been getting codes 0404 and 1335? I think it the ERG Valve and was wounding if I should replace it or have a bypass kit put on and witch one to use?
    Wayne
    veg3 april 08:
    2006 F250
    YOu should deffinately get an EGR Bypass/delete or programmer to turn it off. It has been nothing but problems on the 6.0 and there is even a few TSB's related to that very issue.
      EGR troubles
      Thanks for your post! What is a TSB? Where is the best place to get a bypass/delete kit? What is the advantage to having a bypass kit? How can I turn it off or bypass/delete it or what programmer do I need? Thanks again. Will it hurt anything to run it as it is? I am getting codes but it is not running rough. It seems to run fine.
      veg3 april 08:
      2006 F250
        T.S.B (Technical Service Bulletin)
          dose any know of any kits out there for this mod
          veg3 april 08:
          2006 F250
            i have never seen a kit for this but i am looking for a write up i saw on it...
              try this...
                Does or can the EGR have any adverse effects on mileage?
                Seems like I've read on Powerstroke.org that it can, but can't remember.
                My mileage seems to be suffering here lately...just wondering what might be some causes.
                Time for a programmer with an economy tune!
                Or at least that's how I'd justify it to myself...haha!
                  thanks
                  Thanks for the page
                  veg3 april 08:
                  2006 F250
                    new ERG
                    Had a new one put in on Thurday. Had a trip savannah to D.C got around 18 to 20 MPG so you might look at that thanks
                    veg3 april 08:
                    2006 F250
                      WCM, I might have missed it, but what were you getting before?
                        I was aroumd 13-14
                        veg3 april 08:
                        2006 F250
                          I was aroumd 13-14
                          Ok great, thanks!
                          I might have to look into throwing a block off in there...I could definitely use some help in the mileage department right now.
