95 Dodge Ram with Ford V3
  • 95 Dodge Ram with Ford V3
    I just got finished putting in a used Veggiestroke V3 kit in a 95 Dodge Ram. Customer sold his 03 6.0 Powerstroke and bought a 95 Dodge. Put in a separate Return Valve for Fuel Return and a Air Dog 100 Diesel pump system for the diesel side. RoverHybrids.com supplied a Aluminum Check valve for the Diesel side. Thanks Shane.
    Used the electronic control unit for the Ford modifying the purge circuit to operate the return valve.
    Full automatic functions are retained.
    Purge time is 30 seconds with total after run time of 60 seconds. Just used the main switch without the purge button. It has a fuel pressure gauge to help keep an eye on things.
    Used the newer Dodge VegiRam pressure switch with a 10 psi cut off for the veggie side. Set veggie pressure at 30 pounds pressure with the V3 pressure regulator.
    Thank You Jason for teaching me how to modify the circuit boards wiring to do this.
    See photos here http://www.flickr.com/photos/[email protected]/
    Any questions just ask....Dave at VeggieGarage.com.
    95 Dodge Ram. Running on Recycled Vegetable Oil since 5-07. Sold.. 96 Ford F250 System in progress. 2-16 Sold 2001 F350 System in progress.Sold www.Veggiegarage.com Owner www.AzFuels.com.com
    Looks good Dave!
