Has anyone replaced the drain valve on the stock fuel filter bowl? I have one that is leaking and I need to get it rreplaced. Any tips or tricks to make it easier? How long should it take?
Drain Valve RR 7.3L
If it's coming from the drain valve, it is probably the two o rings. I changed mine out with #90 o rings from Home Depot. It's easy to replace. It's been 13 months since I changed mine. 50 bucks from the Dealership or 3 bucks from Home Depot.2001 Excursion, V3, TS Chip, Walker BTM.
2002 F350 Crew, V2, DP Tuner, Walker BTM.
The valve itself was the issue on our Excursion. The whole thing was $32 (http://catalog.powerstrokeshop.com/p...&subcat2=74463) That is the place to get anything OE for our trucks btw. Don't get raped by the stealership!!
Be aware that 'rubber' o-rings may not last long in ULSD and definately not long in B100 service. Viton is much better...
As for how long? Well, its just (4) screws - but they are a little tough to reach. It took me about 2 hrs start to finish, but most of that was cursing and subsequently cooling off. I replaced the o-rings (viton) in F350 way back when I did the VO conversion, just because I had removed the filter bowl and it was EASY. I'd say it should take no more than 2-3 beers for each person present, but you may want a few more to celebrate the victory!2001 F350 XLT 4x4, dually flatbed. 6637 air filter, single-shot injectors, straight-piped, BTS tunes, 200 gal main VO tank - 180k greasy miles
