6.4l
  • 6.4l
    I have a few customers with the 6.4L and they want to know if anyone is making a system for their trucks. I have told them of the quality and ease of the Vegistroke and they are interested. Any plans on making a system for the 6.4?
    Greased as far as I know, Jason and James were (or are) working on a system for the new trucks. I think there was a bit of work involved with designing the system due to the DPF and what not.
    Hopefully they'll chime on where they are with it.
      Common Rail, CP3, DPF, Tons of sensors, Warranty, Piezo whatever injectors,
        Yea, what he said. It still isn't impossible its just going to take more time and money, both of which are on an extremely short supply right now. Now if the truck already has a DPF delete on it that would change things quite a bit, but we still wouldn't be out of the woods just yet. What we do know is that if you mix the stock tank with a 50/50 mix of GOOD quality oil your 08 will increase its re-gen cycle about 3-4 times more than normal causing you to burn just that much more of your diesel. Stay tuned, we aren't giving up guys.
          Most of my customers have made their trucks "offroad use only" DPF and CAT delete with tuner to compensate for the missing parts.
            yes, what can you do if the DPF is gone and tuned off?
