Since I was due for an oil change and new fuel filters, while I was changing those, I took a few moments today to look over all my lines on the V3. It had been since fall since I'd really been under the truck, so I wanted to make sure all was in order.
My suggestion (or advice I guess) is to make sure none of your fuel lines have gotten any worn spots in them over the winter. I noticed the line that runs up the driver's side head on mine had a slight worn spot on it from laying on top of the trans. Nothing was leaking or punctured, but you could tell it had some wear from vibration. I wrapped two or three layers of the insulation around it and figured it'd be fine.
After that, I looked everything else over and replaced a couple zip ties that had gotten brittle and broke.
Just a little preventive maintainence tip I suppose. Never hurts to check on things from time to time. And since spring is here (or getting closer), crawling under the truck is a bit easier when it's not freezing outside.
