1st Filter Change (5,500 miles)
  • 1st Filter Change (5,500 miles)
    I finally got around to changing my first filter out and I was right around 5,500 miles. I know this is no where near what some guys claim, but I am really please with the number considering how little effort I put into filtering...
    I get pretty crappy oil: very heavy PHO, very thick with huge hunks of crap, french fries and breading. I barely prefilter this at all (sometimes a 600 micron buck strainer, sometimes NOTHING). Then it takes a spin through the simple centrifuge at about 150 degrees and 5-10 gpm. DONE!
    was the filter plugging or did you just decide to change it?
      It was during one of the more recent cold spells...
      The green light would come on for 20 seconds then quit. I figured why push it.
      I think I am going to take your approach Clay and just change it every oil change. For Thirteen bucks, why tempt fate. Also, this requires me to stress much less about prefiltering and spend more time drinking beer in the sunshine.
        now your talking
          Thats awesome.
          I found some locally for just under $9.00
          Do a Google search for Donaldson retailers near you and even if the part number isn't on their site, call them and see what they can do for you. I've been taking the approach of saying "I can get them for $9.50 but I'm looking for a local source that I can pick them up from" ... that encourages them to not jack up the price.
            What is this "sunshine" you speak of????
              Thats awesome.
              sweet, i'll try this but I"m gonna say, "I can get them for 50 cents, but...."
                That's good mileage Fast...way more than I've ever been able to reach.
                However, this last filter that's on there seems to be lasting longer than the others. While I haven't been runing VO, there has been a few times where I've put 10-15 gallons of diesel in there and burned it through.
                Wonder if diesel helps prolong filter life?
                I'd bet I've got between 1500-2000 miles on this one. My best has been ~2500 miles. All others haven't been near that.
                  Originally posted by lyja0317
                  无论是配演什么样的角色,都有远景、中景和近景,所以一套完整的见组照,就应该有全身像、半身像和特写。全身像是看你的形体和表演功力,看你的整体协调性;半身像是看你的角色人 物把握的准确性,和主要肢体语言的演义性;特写是看你的内心情感释放,通过眼神表现出来的感染 力。 最后我再次告诫拍见组照的摄影师朋友,用你的水平+人格负责的拍好,不要无意中毁人前程。不只为钱,成就她 也成就了自己。准备步入演艺界的新人,要对自己负责,准备充分有针对性的婚纱照,用好第一块敲门砖。 如今流行的“个性写真”,却是借自日本语。众所周知,日本人至今还在使用1850个“当用汉字”,以及大量的由这些字组成的“汉 字词”。其中,好多“汉字词”已经有了日本人赋予的含义。在日本语中,“个人写真”有两个意义。其一是“摄 影”,其二是“照片 ”。日本的照相馆就叫个人写真店。对汉语来说,今日的“个人写真”可谓是“先出口后进口”的词。如今,上海 街头,你也可以看到“台北个人写真”,“庭园个人写真馆”等店招。报刊上也常常看到“个人写真”。“个人写 真”经过一些明星不专业的演绎,概念变得模糊暧昧起来,给多数百姓们种下的想法就是——个人写真等于裸体或 半裸体,说好听些是人体摄影。其实个人写真在日文中就是照相,就是摄影,可能它自己也没想到出了个国就改头换脸了。
                  No way! Amazing!!!
                    I wonder why y'all have such short filter life? My first V3 filter lasted 15k miles and I get 5-10k out of the little WIX on my F350 as long as my oil is dry...
                    I don't change filters until FP becomes an issue. When I see below 40psi on hard acceleration or long grades is when I change F350 filter. New filter gives me 80psi at idle and maybe drops to 70psi, belching black smoke from the tailpipe and smokin' the tires! Eventually, the 70psi drops to 65, then 60 and finally I can not accelerate slow enough to keep above 40psi. (Idle pressure still returns to 80psi) Just changed last filter at about 5-6k and I attribute that to the 'bottom of the barrel' CRAP fuel I put in before this trip. (VERY high fats, solid at 70* and prolly wouldn't 'pass' the HPT )
                    I heat and settle (only 100-110*) then pump thru fuel filters (2mic final filter) into trucks.
                    I have same filter head I use in F350 in my pre-filtering set-up. That way I can yank a 'good' filter before a road trip, but still get my 'moneys worth' out of it. I flow these filters there until they just trickle, I get every penny out of'em!
                      Well, I think some of my early filter troubles was probably attributed to some junk in the tank from the manufacturing. After I finally got all that cleaned out of the system (I think), it seems to be doing better. The filter I've got on there now seems to be doing well, so I hope my mileage starts to increase a bit when running oil all the time.
                      I also here lately have been allowing the oil to set much longer (in the cubes, pre-filter barrel, HWH, etc) before using it. I think that helps in allowing all the crud and water to seperate to the bottom. I just always make sure I pour off the good oil from the top of the cubes and leave any fats for later when I can heat them up good in the summer time heat and just pour them through.
                      You'd be amazed how much difference allowing the cubes to sit for an extended period of time will make. My oil looks like coffee when I pour it in the pre-filter barrel, but it's crystal clear. Not mirky or milky at all - at least not until I start getting into the bit of fats that have settled at the bottom.
                      And, I use the tried and true method of the Frybrid still like Clay, so I think that does a good job too.
