The V3 is an amazing system with great customer support and now a forum to keep up on everyone's experiences. Doesn't get any better than this.
Had a few glitches after install that I want to mention as possible help for new installers:
When I did final checks on my system after install, found the pump was blowing fuses. Jason told me to take pump off and check gears for debris. Didn't find any debris, put the pump back on and it again blew fuses. Loosened the hold down bolts on the pump a bit and the pump began working. A day or two later I tightened the bolts more and the pump has been working great ever since.
Fired up my system after getting the pump running and found it would not kick in automatically (no green light, no veg burning). Jason told me to check the pressure. Found the pressure to be a little less than 55 psi. Set the pressure to 65 psi and the system came on and functioned beautifully.
Double checked the timer cards. Found the purge card to be off with the LED staying lit for a full 20 seconds. Reset to eight seconds with no problem. Found the engine run card only keeping the engine running for about 40 seconds. Tried to reset to 55 seconds, but could only get it to 49 seconds with maximum adjustment. Jason is working on a fix for this.
Hope this will help anyone that may experience any of these bumps along the way. What a fantastic system!
Patrick
Patrick
