soy bean oil vs. canola oil
  • soy bean oil vs. canola oil
    I now have over 25,000 miles on vegi oil!:cheers: Most of the miles have been on canola oil but the last 330 gal batch of oil i used was soy bean. Soy bean oil seems to be thinner and easier to pump when it is cold and I can not tell the difference between the two when I run it in the truck. The smell of soy bean oil is not as good as canola...actually is does not have much of a smell at all when burned in the truck.
    What type of oil you are getting and can you tell the difference if you run a different type?
    Triple, I belive the majority of what I'm getting is soybean...at least that's what I remember seeing on most of the labels on the cubes. And I agree, at most temps, the soybean does seem to be thin.
    I've gotten some canola too and it works well as well. Can't really tell any difference though since about 95% of my oil is always soybean.
    All smells the same too...like fried food!!
      Most of what I get is canola i think...Soy is (IIRC) better quality oil and cost more as well.
        100% Canola is what I collect and use. I had a guy ask me the other day if I wanted some Peanut oil as he frys a lot of fish and turkeys in it but I haven't seen that oil yet.
          Triple,
          I use mostly soy but can't tell the difference with other oils I use now and then. Surprised to see that your soy is thinner than canola at colder temps. Never had the chance to use canola, but when I put some store bought canola in the freezer beside my soy, the canola stayed liquid much longer than the soy. Probably should say that my soy is PHO and the canola is virgin oil. Perhaps that accounts for the difference in what I see. - Patrick
            Triple,
            Bingo....
              I should say my oil is pretty close to virgin too...
                I hope your not taking her word for it. Is that like 90% pregnant?
                Canola has a much lower cloud/gel point. I've had a 100 gal tank of 'lightly used' canola stay liquid to -5, even at 70 mph!! No tank heat required!
                  So, apples to apples, canola or soy better at lower temps? - Patrick
                    lancaster,pa
                    Remember my low temps is mid-20's at best. It seems to me that soy is easier to pump at lower temps, but I'm in Texas.
                      Canola, hands-down in my experience. FFA's (primarily animal fat) make a big difference. If warm filtering, these will be in solution, raising the 'gel' point. With adequate tank or fuel pick-up heat and enough heat before filter - it does not matter. Although 'clear' oil is easier to filter.
                      VO is leaving my heated fuel pick-up at 120* right now, only to get hotter in TIH to VO pump and filter - usually about 160-170* as it exits filter, then a few more feet of TIH and a FPHE and I get 190* plus VO before the heads. Also using an aux coolant pump. Overkill? Maybe, but I believe I could burn bacon grease in Alaska.:chuckles:
                        CanolaX2,I have -15 here then add windchill without a problem.When I go to canada I use my no transfat Zytec Canola(liquid @0F).Last year Quebec city -25F no problem cruising down the Transcanadain @ 62mph........greasy
                          Jason,
                          OK, you feel canola is better at cold temps. What does TIH stand for? How are you measuring those temps at various places in your system (what gauges, senders, fittings etc.)? Thanks. - Patrick
                            Jason, Patrick & Greasy,
                            This is good information, you guys are in a better place to speak about types of oil and cold temps. I pefer soy bean so far here in Texas, but i will burn anything I get my hands on.
                              TIH - tube-in-hose (aka HIH - hose-in-hose), 3/8" aluminum tubing inside heater hose w/hot coolant.
                              Currently using IR thermometer to shoot different spots. Have tee's in various spots and will use 1-wire temp senders and multi-position switch to monitor several locations with one gauge.
