Hey guys-just thought I'd give an update on my Donaldson mileage. I hit 10,000 this morning on the way to work and I just happened to be climbing a 12% grade at the time so I floored it-the green light stayed nice and solid. I should probably pick up another one on my way home just so I'm prepared though...
Donaldson mileage update
Originally posted by powerstroke73L View PostHey guys-just thought I'd give an update on my Donaldson mileage. I hit 10,000 this morning on the way to work and I just happened to be climbing a 12% grade at the time so I floored it-the green light stayed nice and solid. I should probably pick up another one on my way home just so I'm prepared though...
Originally posted by lancaster,pa View PostAmazing!! Basics of your filtration system? - Patrick
Once I have a full drum of of diesel/veggie mix I hand pump it into the centrifuge barrel. The centrifuge is powered by a 1/2 HP motor coupled to a Haldex hydraulic pump. I heat the oil by passing it through a 1-1/4" steel pipe with two 5500 watt/240 volt hot water heater elements in it. Pressure to the centrifuge is controlled by a relief valve set to 90 psi so operation is totally hands free. I simply plug in the pump/heaters and let it run. My run times have drastically increased in these cold temperatures as I've found that I get the best results holding the oil at a temperature of 160 degrees F for at least two hours. It's taken longer and longer as temperatures in my garage have been approaching zero latelyHowever, it's not bad as I'll usually start it up when I get home from work, eat dinner, watch TV, do stuff around the house, etc...and shut it down before I go to bed. Due to the amount of pre-filtering I do I typically get no more than a 1/16" layer of black gunk on the inside of the rotor.
To get the oil out of the centrifuge barrel I have a second ball valve that I can open to divert the flow to a Goldenrod Waterblock 15 micron fuel filter. The purpose of this is more to catch water than particles and I simply use them until they plug. I'm going to see how much life I can get out of this Donaldson as I changed my last one just for the hell of it at 8000 miles. I had no signs of it plugging, etc...Currently dieselless!
Originally posted by fiveohpatrol View PostI'm about 6500 right now on mine, and very surprised that it's still goin. I pre-screen through a 100micron barrel screen and then gravity feed through a 5micron water filter.2001 F350 XLT 4x4, dually flatbed. 6637 air filter, single-shot injectors, straight-piped, BTS tunes, 200 gal main VO tank - 180k greasy miles
Originally posted by skyskijason View PostCareful, water filters are not 'absolute' rated filters. IOW, they let particles much larger than their 'rating' thru. It is generally considered a good idea to use a real fuel filter, such as a fuel tank transfer pump may use (ie, the goldenrod filters) as your 'final' filtration.Currently dieselless!
I too have a dieselcraft(oc50) and love it,9200 miles on this filter2000 7.3X V3 So much fun,so little time,Support small Oil,burn WVO,Free and greasy down the road I go!!!!!!!!!!completely self sufficient and proud of it. (Wood furnace.....X.......solar pontoon....solarsheat twins this summer.....I don't Know much.......I'm just a hillbilly with too many guns..............
Originally posted by powerstroke73L View PostThe Goldenrod elements are relatively cheap and last a while. The waterblock elements are $11.99 at Tractor Supply. They may be cheaper if you buy in bulk through NAPA or any other large parts chain.
Goldenrod water-block = 15 mic
regular Goldenrod (not water-block) = 10 mic and about 1/2 the price!!
Also, the non-water block will plug up just as fast if there is any water present in VO. The water-block will NOT stop emulsified water in VO. There is no advantage to using water-block IMHO.2001 F350 XLT 4x4, dually flatbed. 6637 air filter, single-shot injectors, straight-piped, BTS tunes, 200 gal main VO tank - 180k greasy miles
Powerstroke,
Were all of those 10,000 miles on oil filtered after you made those changes to simplify your filtering process? - Patrick
Fiveo,
Also great mileage you are getting on your filters with a simple process as well. Can you describe the type and condition of the oil you are collecting (kind of oil, how used it is, color, stored inside or out and what type of container until pick-up, etc.)? - Patrick
Originally posted by lancaster,pa View PostWere all of those 10,000 miles on oil filtered after you made those changes to simplify your filtering process? - Patrick
Anyway, what I eventually realized is that unlike other conversions where PHO and fats can cause lots of problems due to lack of adequate heat, the V3 can heat and burn pretty much anything without a problem, so in essence, by using cold upflow I was throwing away good usable truck fuel. So now I just blend my oil with a small amount of diesel to start with and CF it, PHO, fat, and all.
Originally posted by CHenry View PostI just change mine at 5k miles when i am changing the crank case oil....why mess with longevity on a $11.00 filter.Last edited by powerstroke73L; 01-28-2009, 09:56 AM.Currently dieselless!
Originally posted by lancaster,pa View PostFiveo,
Also great mileage you are getting on your filters with a simple process as well. Can you describe the type and condition of the oil you are collecting (kind of oil, how used it is, color, stored inside or out and what type of container until pick-up, etc.)? - Patrick-Drew
Originally posted by fiveohpatrol View PostI definitely think the quality of the used oil is the key in my setup. It's all canola oil that's really pretty clean when I get it. It's never stored outside, and never sees water. One of the places puts it in clean 5gallon buckets, another puts it back in their cubies, and another leaves it in small metal pots to cool until I get there and dump it into buckets. I only get about 15-20 gallons a week like this though.
