WOW! I just received the new pressure switch and relay from DFA. The relay harness is not what I imagined it would be. They have (as usual) thought of everything. They have designed it so if the relay were to fail your stock fuel pump will continue to work. I will post up some pictures to show you the quality of this relay harness. It is top notch. Thanks DFA...
DFA does it again!
Awesome...sounds like they took care of you!
Defintely post up some pics...I'd like to see the setup.Greasin & Grinin
Originally posted by triplemoutdoors View PostWOW! I just received the new pressure switch and relay from DFA. The relay harness is not what I imagined it would be. They have (as usual) thought of everything. They have designed it so if the relay were to fail your stock fuel pump will continue to work. I will post up some pictures to show you the quality of this relay harness. It is top notch. Thanks DFA...
Lets see here, what is it Albert Einstein once said “The definition of stupidity is doing the same thing over and over again and expecting different results.”
:cheers:1999 F-350 Lariat 7.3 385,000 miles and counting
