Questions for all as I continue to build my set-up and storage and evaluate tank options, etc.
I notice there's a lot of discussion of poly and most folks are using totes or other plastic barrels. Also, I notice all the heated vehicle tanks are designed out of aluminum and not steel.
Is the going wisdom that metal tanks are no good to store VO? A parallel question - is aluminum okay for mid-term storage (as in in-the-vehicle) but not steel?
Reasons I'm asking are twofold. First, because I am still considering options for the truck tank. Second, for storage, I have a line on a 1000-gal steel storage tank with a pump unit for $100 and some other large 800 and 600 gallon storage tanks for cheap. Also, I've found tons of postings on craigs list for folks giving away their old 275 or 330 gallon steel home-heating-oil tanks (ie diesel tanks), but folks are charging upwards of $150 for 275 gallon IBC plastic totes. The final thing is that I have a line on some $10 steel 55-gallon drums, but the 35-gallon plastic drums I've found cost a bit more. (This would be for moving around smaller volumes of stuff once processed for local moving around and storage, not for collection.)
I appreciate your responses and experience!
Eric
Eric
