maintenance while tank is out?
  • maintenance while tank is out?
    I have to take the vegistroke tank out of the back of my truck today to install a bedliner.
    While the tank is out is there anything I should clean out or look for while there is no oil in it?
    Thanks,
    Colin
    Colin
    2002 F350 4x4 Cab Chassis Flatbed
    Thanks,
    Colin
    Nope...unless you suspect there is something in it that needs to come out?
    Be carefull to plug the holes so you don't get coolant or dirt inside the tank.
      I guess you could sweep any leaves out from behind it like I need to do...haha.
      Kidding...
      Like Clay said, unless you think there are problems with it, I'd plug the holes and not worry about it.
        If its a spray in liner grind any holes thru bed to bare metal,then dull edges this will give longevity to the liner around said holes...............
