There's been a lot of talk here about the Donaldson's water blocking capabilities and filter life in general but I've been wondering about something. I got 10K miles out of my first Donaldson and changed it despite no issues with the light turning off or flickering, just figured it might be a good idea. I'm approaching 10K miles on the current filter (2nd oil change since the last Donaldson) and I'm wondering whether or not to leave it on to see if it makes it to 15K. What I'm concerned about is what will happen when and if the filter plugs. Will it simply plug and cause the system to stop working (green light goes off until the filter is changed), or could the filter plug and the media rupture before the pump shuts down? Just wondering...James? Jason?
Donaldson plugging vs. rupturing?
Originally posted by powerstroke73L View PostThere's been a lot of talk here about the Donaldson's water blocking capabilities and filter life in general but I've been wondering about something. I got 10K miles out of my first Donaldson and changed it despite no issues with the light turning off or flickering, just figured it might be a good idea. I'm approaching 10K miles on the current filter (2nd oil change since the last Donaldson) and I'm wondering whether or not to leave it on to see if it makes it to 15K. What I'm concerned about is what will happen when and if the filter plugs. Will it simply plug and cause the system to stop working (green light goes off until the filter is changed), or could the filter plug and the media rupture before the pump shuts down? Just wondering...James? Jason?
I'd ride it out and see what it does. Sounds like your filtering process is doing a great job. Most I've ever gotten out of one was 2500-2700 miles I believe.
I highly doubt you'd rupture the casing on that filter. If anything, I'd imagine the seal on the bottom of the filter would give out first. Not even sure if the FASS is capable of producing that much pressure.
Keep us posted on how long it lasts.
Thanks!Greasin & Grinin
Originally posted by Marv View PostI highly doubt you'd rupture the casing on that filter. If anything, I'd imagine the seal on the bottom of the filter would give out first. Not even sure if the FASS is capable of producing that much pressure.
Anyway, I took the Goldenrod element out and examined it. It had failed where the paper media attached to the plastic "body" of the filter. The paper simply tore away under the pressure. I'm pretty sure the pressure in the line hit about 60-70 psi before it finally failed, but it happened very fast so I'm not entirely sure. Anyway, I think what I'll do is leave this one on until it plugs and then cut it in half with a sawzall to examine it.Currently dieselless!
and as the Donaldson begins to clog, the pressure on it doesnt increase, the fuel is still running at 75 psi and what can't get through the filter is returned. The pressure post filter decreases and prefilter pressure stays the same.
Unlike your goldenrod setup....
Originally posted by CHenry View Postand as the Donaldson begins to clog, the pressure on it doesnt increase, the fuel is still running at 75 psi and what can't get through the filter is returned. The pressure post filter decreases and prefilter pressure stays the same.
Unlike your goldenrod setup....Currently dieselless!
Originally posted by powerstroke73L View PostGood point. I guess I'm just still in disbelief that I've been driving around mostly for free for close to six months now...lol
I also don't think the filter will fail, as I have been through many of them with no signs of anything failing at all. When they die... the light blinks and thats all.Vegistrokin since 08/23/08
As others have already said, I think you'll be fine.
If the Goldenrod failed at 60-70 psi, you should be more than fine with the Donaldson. My system is set to operate at 75 psi.Greasin & Grinin
Every truck I even trucked in had donaldson units,good stuff.FYI they also make air filters for large box stores that purify the air in malls and large department stores.Theres one you can see in southern NH,it looks like our filters,but 25 feet tall,its hooked up to a mall off of I-93 south bound...........
You don't need to worry about the Filter rupturing. I have been using them for over 4 years now and have (knock on wood) never had one fail or heard of one failing. Donaldson is just about the best quality brand for filters out there. This Specific filter is actually OEM for the Caterpillar 3176 and 3406 series industrial and agricultural engines. I have done a lot of research on filters and nothing else comes close. And like Clay said the design of the system is such that the filter will never see more than system pressure. The pressure is regulated prior to the filter, not after so a plugging filter will cause post filter pressure to drop, but pre-filter will not rise. Here are the specs for the 555823.
Donaldson P555823
Beta
Nominal 2 Absolute 9
Temperature
Pressure 100psi
Vacum
Surface area 1075²in
Media type celluose
Dirt holding capacity 22grams
Donaldson EFF9092
Beta
Nominal 2
Absolute 5
Temperature
Pressure 75psi
Vacum
Surface area 758²in
Media type synthetic
Dirt holding capacity 28grams
Also listed is the "High Performance" version as well. Holds slightly more dirt, a little smaller and better at water seperation, filters better and costs about 2 to 3 times as much.Last edited by Fordnut74; 01-08-2009, 10:26 AM.1999 F-350 Lariat 7.3 385,000 miles and counting
Ok-you guys have gotten rid of all my doubts.
Originally posted by Fordnut74 View PostAlso listed is the "High Performance" version as well. Holds slightly more dirt, a little smaller and better at water seperation, filters better and costs about 2 to 3 times as much.Currently dieselless!
Originally posted by powerstroke73L View PostOk-you guys have gotten rid of all my doubts.
Just one more question. It was my understanding that the Donaldson will absorb water until it swells and plugs. So IF (and I know I'm playing Murphy's Law here) somehow a substantial amount of water got into my tank, it would simply plug up, the green light would go off, system-no-worky until the filter is changed/wet fuel is drained and replaced right? Kind of like a circuit breaker?
