Having recently survive a 5 day black out, I have been searching for new ways to generate electricity without a typical small engine generator. Seeing how most people here are creative in using alternative fuels, wondering if anyone has a system to run the truck on an inverter or PTO generator? With the V3 running, it should be an outstanding alternative fuel for emergencies. But I don't know what maximum wattage you can get out of the inverter with the truck running (alternator = max watts, etc), or if the 7.3 is capable of attaching a PTO generator? Any of you survivors dealt with this or have any thoughts?
F250 V3 WVO generator?
i have considered a PTO gen for the tractor. It runs on Vegi and can idle for days on a small amount of fuel.
The PTO generators at northern tool aren't to pricy.
For now i have a coleman gas fired genset that works pretty well and doens't gobble too much fuel.
Diesel generators(KUBOTA) used foer powering message signs (like the ones on I-93)can be had from a paving or road construction company for $1500-$2000 used.This would power your whole house,and comes on a trailer.I saw one on NH craigslist last month for $1295........look around you'll find one............2000 7.3X V3 So much fun,so little time,Support small Oil,burn WVO,Free and greasy down the road I go!!!!!!!!!!completely self sufficient and proud of it. (Wood furnace.....X.......solar pontoon....solarsheat twins this summer.....I don't Know much.......I'm just a hillbilly with too many guns..............
Extended idling on VO is prolly not a good idea. That said, there are a few generators made just for this and a PTO-equipped truck would make it even easier...2001 F350 XLT 4x4, dually flatbed. 6637 air filter, single-shot injectors, straight-piped, BTS tunes, 200 gal main VO tank - 180k greasy miles
I got it,one of my old box trucks had a PTO on it with a RPM adjuster.I bought it through Quality Insulation in Meredith NH(theres on in Nashua too).This was used to blow insulation into attics,maybe you could write it off for you BIZ(I take it your in construction).............2000 7.3X V3 So much fun,so little time,Support small Oil,burn WVO,Free and greasy down the road I go!!!!!!!!!!completely self sufficient and proud of it. (Wood furnace.....X.......solar pontoon....solarsheat twins this summer.....I don't Know much.......I'm just a hillbilly with too many guns..............
I know this is powered differently but thought you might find it interesting.
http://greeninc.blogs.nytimes.com/20...nerator&st=cse
for those who don't want to read the whole article;
A guy wired up an inverter to his Prius and was able to power several things in his house during power outages.Colin
2002 F350 4x4 Cab Chassis Flatbed
Originally posted by skyskijason View PostExtended idling on VO is prolly not a good idea.
Generators usually aren't idiling anyway, right? Wouldn't the "load" from being a generator make it run at a decent RPM?Vegistrokin since 08/23/08
Originally posted by CHenry View PostA PTO generator for a tractor makes full power at an idle RPM. The PTO genorator i saw ran at 700 rpms...an idle. Other gensets have load switches that power them up according to load level.Vegistrokin since 08/23/08
Originally posted by Jack_Toepfer View PostI hear that a lot, but there are several people living off of the grid on primarily WVO, and their electricity is coming from diesel generators running VO.
The problem is combustion temps. Diesels seem to tolerate VO better w/higher temps in the combustion chamber.
Here's some science to go with that. Flash Point of diesel is 125-250*F and FP of VO is over 600*F. Now there is more than just FP playing a role in the combustion chamber, but it stands to reason that the hotter the fire the better the VO will burn.
For me, this helps justify the accelerated tire wear consistent with generating the highest possible combustion temps!!:chuckles:
Yeah, my driving habits have changed after a couple years of not having my right foot connected to my wallet...2001 F350 XLT 4x4, dually flatbed. 6637 air filter, single-shot injectors, straight-piped, BTS tunes, 200 gal main VO tank - 180k greasy miles
Here's a really cool idea -- generate some/all of your home's electricity on a Lister diesel/WVO generator. I stumbled across this when the thread gave me an idea to research WVO generators. I have this crazy notion of running a WVO generator and/or installing solar PV and/or putting in a geothermal system to provide my energy needs to get off the grid...:chuckles:
http://www.centralmainediesel.com/or...sp?page=L09989
Central Maine Diesel in Bangor, ME'02 7.3L Excursion Limited; ~242Kmi total; ~157Kmi on WVO
There are lots of folks over on infopop who have used various lister knockoffs to go off grid or supply emergency power. They run at very low RPM but they're also very crude machines (very simple design, loose tolerances) so I think its safe to say that they tolerate WVO very well. They were designed to provide power for gensets, water pumps, farm operations and other tough jobs in remote places where replacement parts, proper tools, and quality fuels are often scarce. I wonder how they would run on WMO, ATF, etc...? That way you could park one next to a 275 gallon oil tank and fill the tank with a mixture of filtered waste oils from a variety of sources to be at the ready when its needed. I'd just make sure the exhaust stack was nice and high
*EDIT*
Check this out - http://www.f1-rocketboy.com/lister.htmlLast edited by powerstroke73L; 01-09-2009, 01:28 PM.Currently dieselless!
