I was just running through some rough numbers, trying to figure out how much diesel I'm using, mainly out of boredom, and wondered how much diesel is purged when the V3 does the shutdown purge? Assuming it's right at 10 seconds, and the stock pump is around what, 100gph (wild ass guess), with minimal restriction in the system is it dumping .28 gallons back into the WVO line/tank? (100gph / 3600 seconds per hour * 10 second purge)
I've been doing multiple short trips and as a result am using quite a bit of diesel, just curious how much of it is going back into the WVO tank because of the purge compared to how much I'm using during startup.
