I know this pump has been mentioned in a couple other threads because it is very, very popular. I didn't want to go too off topic in them, because this thread is strictly about this pump, its applications, and improvements that can be made to it.
This site had some interesting points concerning the pump, be it from Harbor Freight or Northern Tool. Have any of you had these problems?
I don't want to JB Weld a pipe into the pump because I paid $10 for the warranty that allows me to bring it back after it burns out for the next 2 years.
Is anyone using the fuse they are referring to or have any of you experienced the capacitor burn out?
How many of your pumps are leaking from the pump/motor seal?
It is still in my truck because I bought it on lunch (along with a bunch of other wonderful HF goodies) and I have to buy the pipe on the way home. Is it worth trying to re-thread the housing to correct the issues? 1" Black pipe?
I bought this as well - 45185-1VGA It is the 3 Way Power Grounded Outlet. I'm going to cut off the 3 way and use the rest of it on the pump. The 3 way will go on one of my extension cords that is already cut. The plug end will go on the pump. Does that sound like it will work?
I'll be priming it with the HF Air Powered Pump like FastCote is doing. Would running them both double my results? That would help in the cold winters here.
I'd like to leave everything in the barn and hook it up to a light switch on the outside of the barn. When I pull my truck up I flip the switch. The switch would turn on the air pump as well as the electric pump. Next to the switch is a box, cut into the wall, which contains the hose/handle/valve. I should be able to turn on the valve and get oil almost immediately. Close the valve when I'm done and shut off the switch. Yes/No?
