Just finished up with corn harvest, and used my F250 to haul grain to the elevator while burning veggie. The total weight of my truck, two gravity wagons, and corn ranged from 47,000-50,000 lbs depending on how full the wagons were. Just wanted to report that the V3 performed flawlessly. It was funny getting comments from the guys that work at the elevator that my truck made them hungry every time I pulled in!
Towing WAY past Ford's limit while on Veggie Oil
NICE! Good work, I love it. And a 6.0 at that!Jus think what a 7.3 can do!!
hehehe
Originally posted by rabidsnowmobiler View PostJust finished up with corn harvest, and used my F250 to haul grain to the elevator while burning veggie. The total weight of my truck, two gravity wagons, and corn ranged from 47,000-50,000 lbs depending on how full the wagons were. Just wanted to report that the V3 performed flawlessly. It was funny getting comments from the guys that work at the elevator that my truck made them hungry every time I pulled in!
Originally posted by lancaster,pa View PostInterested in how you would rate the power available using veg and pulling such a load. How would you compare it to diesel with the same load? - PatrickNC State law defines biodiesel as ''any fuel or mixture of fuels derived in whole or in part from agricultural products or animal fats or wastes from these products or fats.''
Originally posted by lancaster,pa View PostInterested in how you would rate the power available using veg and pulling such a load. How would you compare it to diesel with the same load? - Patrick2008 F350 CC SB Lariat Spartan tuned
Originally posted by CHenry View PostMan that load just doesnt look that heavy but i guess corn is heavier than it looks.2008 F350 CC SB Lariat Spartan tuned
Nice pic and nice haul Rabid...that's a lot of weight.
What type of hitch does the grain wagons have on them?Greasin & Grinin
Originally posted by Marv View PostNice pic and nice haul Rabid...that's a lot of weight.
What type of hitch does the grain wagons have on them?2008 F350 CC SB Lariat Spartan tuned
Originally posted by rabidsnowmobiler View PostThe tongue on the wagon has a U-shape to it that a pin drops through. Imagine using a 2" ball/reciever combo that is typically found on trailers, but replace the ball with a pin. It's the setup that is used on 95% of farm implements that hook to the drawbar of a tractor. The upside of this design is that it's easier to hook up as you don't have to be spot on when backing up. The downside is the slop in the joint, which requires the use of a cushion hitch on the truck to eliminate some of the shock on the drivetrain.Greasin & Grinin
