Another V3 in the family
  • Another V3 in the family
    Found a oppty we couldn't pass up on a DFA rebuilt V3 and talked my bro into taking the plunge... He does about 25k mi /year so he's a good candidate.
    He is going to TIG up a tank for the spare tire location (like stock X tank) for WVO.
    We think we can get ~40gal under there with some work.
    It's a 02 F250 w/ 114k mi btw...
    Wilson,
    Any chance you guys would be interested in selling one of those spare tire tanks when you get em done? - Patrick
      Would it be cheaper just to buy a X tank from a salvage yard? If the shoe fits,wear it. I used to drive truck thru NJ a while back,I think it was Elizabethtown that there was a big salvage yard with alot of Fords (mostly exploders at that time) the name isn't coming to me right now...maybe ALLIED salvage? well just a thought,and a good way to recycle......greasy
        Wilson,
        Sure thing. I will talk w/ my bro and take lots of pics...
        One thing we want to do right is the fill neck location.
        But the tank will be done in about a month +/- a week I'm sure.
        Greasy- I searched high and low for an EX tank. No one had it and my brother is a great welder so he said screw it I'm making it the way I want.
        PS- brand new at 10% over dealer cost the Ex tank is like 600-1500 depending on the year. I had no idea how they could be that different across all the years...
          Good score! If I were building a custom tank, for max efficiency, I would design the heat and baffling in such a way that the heat is focused just around the fuel pick-up as opposed to 'heating the whole tank'...
            Any thoughts to putting a drain in the tank? Where are you thinking of placing the filler neck? Using stainless or aluminum for the heat exchanger/fuel pick-up? - Patrick
              Just out of curiosity, would the stock Ex tank be steel? If so, I'd give that some thought before I used that for a vegi tank.
                Oh and glad to hear another vegi owner will be on the road! Congrats to your bro!
                  no sir Ford calls it POLY,I call it plastic.44 gals total.If any one is good at plastic welding I have seen a 60 gallon "juice" barrel cut down to 37 gallons,and it fits where you want to put it,encapsulated with hi-density foam,with a custom diamond plate skid plate.It was at a "greasestock" type event on a 99 powerstroke f-350.It was towing a full blown mobile filtering rig capable of 200 gallons per hour filtering(nice 22 ft enclosed trailer,real stealth).Sorry I am rambling,if you can think it ,it can be done........greasy
                    Sure it's possible.
                    filler neck would ideally go right next to diesel fill. I put mine there and it's perfect.
                    pickup will be targon tubing and heat exchg is alum.
                      That's interesting....I would have guessed it was steel.
                        There was a guy on FTE that converted his EX to Cummins powered, there was a good shot of the tank in that build-up.
                        What are you guys doing with filler-necks so you know when to stop filling?
                          filler neck is in the stock location.. Just like I did my X.
                          (pics in that forum)
