B100 in the diesel tank may not be good. Lets put it this way - I'm not using it until I get a 'fuel stabilizer' that mitigates polymerization. I have some BioExtend 30 on the way...
So, I changed diesel filter as a matter of preventative maintenance before I left Seattle. I was HORRIFIED to find signs of polymerization in my factory diesel filter. It looks JUST ike the pics in that Bosch report C. Goodwin likes to quote that says don't use more than B20 in their pumps. Ok, then about CO when I was out of VO and burnin' (more
) B100, I began to loose fuel pressure under load. Stopped and bought a new diesel filter and found more of same stuff in filter and filter bowl - damn. Burned a couple tanks of D2 before getting more VO. I JUST bought more diesel the first time the other day, it was down to 1/4 tank (uh, 2800ish miles since last purchase). Yesterday, fuel press (on D2) down again, and yep, more poly stuff in bowl and dead filter.
The 'stuff' is a lining on bowl and small flakes of gritty substance that settle to bottom. I took some pics last nite, but didn't have time to upload'em yet - not sure if they tell the tale anyway.
So, I suspect this stuff has 'contaminated' the diesel tank and my issues have just begun. I also wonder if the copper guts in my stock diesel pump are lined w/poly, maybe hampering its ability to do its job.
WHY?? I think it is likely to do w/the SAME B100 sitting in the 'pressure cooker/poly maker' previously reffered to as the diesel filter bowl. This metal container sits on top of a HOT engine for HOURS and HOURS at a time. Then I flip on diesel pump to purge and pump almost ALL of that stuff back to diesel tank. Then I do it again the next day, and the next - once this summer 7500 miles and only 1/2 tank of B100. THATS ALOT OF COOKIN' FRIENDS!!!
I have been using B100 for 1.5 yrs now. Anyone else w/similar usage to me?
No problem at all on VO!
