Anyone know what size and where I can get one for the v3? I don't know how, but I lost the thing.
Big A$$ Allen wrench
2002 F350 2WD CCLB 7.3 Bone Stock "Rusty"Tags: None
yeah its 5/8"
I need to find one myself...my V3 didn't come with it so i just figured it would be easy to drop in the local tool store and buy one but so far i have dropped in on 3 tool stores and when i ask for a 5/8" alan, they look at me like my head is on fire.
Was gonna look on ordering one off the net somewhere.
thanks for the heads up. I will call before dropping in.2002 7.3 Excursion Limited V3 w/40 gal RDS Tank, +50 gal or 100 gal aux cargo tank,
Originally posted by triplemoutdoors View PostIf I were you I would get a 5/8" hex socket. You can get them at Sears for about $20. It is much easier to use with an extension and ratchet vs. the allen wrench...lots of stuff in the way.
I think a ratchet would make the job much, much easier...Greasin & Grinin
By the way, anyone else had problems getting the allen wrench to fit into the pre-filter cap?
Don't know if the cap is dinged up or what, but I can barely get the wrench in there halfway when pulling that thing out. Next time I have it out, I guess I'm gonna take a file to it and see if I can't clean it up a bit.Greasin & Grinin
Originally posted by Marv View PostBy the way, anyone else had problems getting the allen wrench to fit into the pre-filter cap?
Don't know if the cap is dinged up or what, but I can barely get the wrench in there halfway when pulling that thing out. Next time I have it out, I guess I'm gonna take a file to it and see if I can't clean it up a bit.-This space for rent-
Originally posted by triplemoutdoors View PostI think it is the allen wrench and not the cap.
I wondered that as well Triple, but I never think to look at it once it's out of the manifold.Greasin & Grinin
Originally posted by John_DFA View PostThat is what I do here in the shop because we use the same one over and over again the edges get tough to fit in the cap. Just take a file and soften the edges a bit but not the corners and it should work just fine.
Excellent John, thanks for the tip. I'll be sure to check it out next time I have it out of the manifold.
Thanks!Greasin & Grinin
called sears, autozone, advanced auto, NO LUCK. Can anyone send a link to where I can order one???2002 7.3 Excursion Limited V3 w/40 gal RDS Tank, +50 gal or 100 gal aux cargo tank,
Originally posted by billman View Postcalled sears, autozone, advanced auto, NO LUCK. Can anyone send a link to where I can order one???
Bill, I've been meaning to find one of these. If I happen to come across one before you find one, I'll send you the info.
