I like the way the system is wired up (for the most part). I have a remote starter and can hit the magic buttons to keep the truck running for 20 minutes. I wasn't sure if that would work but it does - cool.
Anyway, let me describe something odd...
7 times out of ten, when I key off the truck, the radio turns off while purging, then back on again for the remainder of run time (NOT desired).
The other 3 times out of ten, when I key off the radio stays on for both purge and run. (better, but odd that it does it)
In either case, if I get out of the truck and close the doors before the shutdown cycle finishes the radio stay on for some undetermined amount of time unless I open the door, then it goes off immediately.
Is everybody else experiencing this?
