WVO Programmers
  • WVO Programmers
    OK guys I hope some of you looked at my Libby on youtube (CRD Liberty).I need to find the best "Auto Switch" for it .I know V-3,seriously,wife forgot to purge,luckily I caught it in time.Should I go VO control or Dare i say Co-pilot.I was gonna wait for PAL, by the other boys in Seattle Area.But I know thats gonna be 6 weeks to 6 months out.I need some help,I dread Paying MB prices for Italian VM injectors.Clay you ever look at these things..
    I have installed 3 co-pilots and one VO Controller. The Co Pilot has an alarm. Not very loud either. You have to wire your solenoids from an always hot source for the alarm to work.The VO Controller will give you the option of having a auto shut down. But the trick is to find the proper wire for the auto shut down option. Unless someone at the VO Controller support website has done one you will have to find the proper wire on your own. You will need a factory wiring diagram of the fuel system to do this. Check their website first.
    Although once you find the proper wire for purge shut down you could use timers and relays to build the circut. Get the wiring diagram...
    Dave
    95 Dodge Ram. Running on Recycled Vegetable Oil since 5-07. Sold.. 96 Ford F250 System in progress. 2-16 Sold 2001 F350 System in progress.Sold www.Veggiegarage.com Owner www.AzFuels.com.com
      Why not build your own? Auto-shutdown/purge is not required. Just a 'forgot to purge' alarm. The buzzer itself is a Radio Shack item and the circuits are simple. A 555 timer and pot. switch to adjust purge time and a couple of relays for valves and/or pumps... Of course I don't have time either! My junk is still all manual (and I haven't ever forgot to purge in 70k miles).
        No, i haven't...why?
        Wheres a link to your youtube libby?
          clay check your pm to shed some light on things
            Saweeet!
            Now if i could just find a conversion for it....
              I think I know someone with one of those converted.Good price but make sure Recalls have been done.That would be EGR,Torque converter,as well as PCM reflash.If you buy it I found a kit to work with no EGR=no check engine light with even better MPG.greasy
                Would a turbo-timer type device work? It would require some thinking but I believe it would opperate as well as the V3. I think they are working on the same concept actually.
