What are you guys using to clean the dried vegi oil off your tank? I am getting a sticky mess around the fill tube and have tried simple green and a few other chemicals with poor results.
Dried Vegi Oil on Tank
I've been wiping it away while it is wet.
I was told by a couple people there is a "Simple Purple" or something with purple in it that works better than anything else.
It should be on the shelf right next to the Simple Green.
I haven't allowed any oil to dry yet, so my experience is limited.Vegistrokin since 08/23/08
I just cleaned up my old tank the other night to get it ready to ship out when i find a buyer. I had a nice 2 year old dryed streek that ran down below the filler cap in the back of the tank all the way to the bottom. Purple power didn't touch it. It laughed in the face of Break Clean...i use a wire brush and ALOT of elbow grease and it finally came off. NEVER let it dry (for 2 years)
I've used some Mr. Clean spray that seems to work well. Never tried it on 2 year old oil though...haha.
I would think most of your common grease cutting cleaners would to it, but I could be wrong.Greasin & Grinin
My bio-diesel producer i deal with makes Glyserin soap,works great,use gloves if you like your fingerprints,wait a minute,clay couldn't that aid my escape
I'm sure some would disagree, but I use carb cleaner to clean up just about anything. Haven't seen much it can't get rid of. I like the cheap stuff at Wal-Mart the best because it doesn't leave behind an oily residue like some carb cleaners do.2000 7.3 F-250 w/ V3
Originally posted by Jack_Toepfer View PostI wonder if spraying it with something like WD-40 would protect it from future spills?Greasin & Grinin
purple power seems to work well. I'm not sure about the dried on stuff. i try to clean it up as soon as possible.2002 7.3 Excursion Limited V3 w/40 gal RDS Tank, +50 gal or 100 gal aux cargo tank,
