I was sitting in my driveway yesterday programming pre-sets on my Sirius radio. You can pre-set up to 30 stations so it took a little while. I had just gotten home about 10 minutes before so the V3 manifold was still plenty hot. When I flipped the key to "ACC ON" the V3 light came on of course (it was in auto position) and the pump started up. I'm so used to seeing the light on the dash (and it had been a long day at work...) that I didn't give it a second thought until I heard a kind of gurgling noise coming from underneath the passenger side. It was then that I realized the V3 was pumping. I quickly shut the key off and put the V3 on manual off and went back to what I was doing. When I finished I started the truck and put the switch back to auto and drove around the block. Everything was fine, but I'm wondering what would happen if I had left it going for a minute or two. Would it have caused damage or would the V3 have sensed that the truck was not running and simply recirculated fuel back to the tank?
More tech questions-key on, V3 hot, engine not running?
Originally posted by powerstroke73L View PostI was sitting in my driveway yesterday programming pre-sets on my Sirius radio. You can pre-set up to 30 stations so it took a little while. I had just gotten home about 10 minutes before so the V3 manifold was still plenty hot. When I flipped the key to "ACC ON" the V3 light came on of course (it was in auto position) and the pump started up. I'm so used to seeing the light on the dash (and it had been a long day at work...) that I didn't give it a second thought until I heard a kind of gurgling noise coming from underneath the passenger side. It was then that I realized the V3 was pumping. I quickly shut the key off and put the V3 on manual off and went back to what I was doing. When I finished I started the truck and put the switch back to auto and drove around the block. Everything was fine, but I'm wondering what would happen if I had left it going for a minute or two. Would it have caused damage or would the V3 have sensed that the truck was not running and simply recirculated fuel back to the tank?
It doesnt sense anything....lol...the V3 has a regulated return to the vegi tank and it will send all the vegi its pumping back to the vegi tank.
Likewise when your driving the return line is still sendng the excess fuel back to the tank.
No damage down.
Originally posted by Jack_Toepfer View Postum... so I have to have the V3 off if I'm parked by a bonfire with the radio on?
I'll have to try mine this afternoon when I leave work.Greasin & Grinin
Originally posted by CHenry View Postyour diesel pump is activated in the "acc on" key position along with your glowplugs so the vegistroke is to.
The position just before you start the engine, or the position when you turn the key backwards?Greasin & Grinin
Originally posted by CHenry View PostIt doesnt sense anything....lol...the V3 has a regulated return to the vegi tank and it will send all the vegi its pumping back to the vegi tank.
No damage down.
I think the only 'return to tank' is purge. The 'bypassed' fuel from fuel press regulator returns to suction side of pump. This is just one of the beautiful things about V3, no heated fuel is 'wasted' by returning it to tank.
Since I've never seen V3 install instructions, I don't know where they recommend tapping the power from - but 'ass'ume the VO pump would only recieve power in 'key on' (just before start), just like factory diesel pump. I'd actually like to use the factory pump power supply for VO, so the safety stuff for auto shut off in an accident would still function. So hopefully in the unlikely event of a crash I don't have to crawl through a spray of HOT VO when exiting the truck!2001 F350 XLT 4x4, dually flatbed. 6637 air filter, single-shot injectors, straight-piped, BTS tunes, 200 gal main VO tank - 180k greasy miles
Originally posted by skyskijason View PostI think the only 'return to tank' is purge. The 'bypassed' fuel from fuel press regulator returns to suction side of pump. This is just one of the beautiful things about V3, no heated fuel is 'wasted' by returning it to tank.
Originally posted by CHenry View PostMaybe, i don't know if thats a new thing with the V3 or not, matters not though, my "point" was the VO does recirculate unused fuel when the pump is on.
It would be inconvenient to have to turn off V3 to utilize acc. position on key switch. You would not want all that drain (FASS & filter heater) on a non-running engine.2001 F350 XLT 4x4, dually flatbed. 6637 air filter, single-shot injectors, straight-piped, BTS tunes, 200 gal main VO tank - 180k greasy miles
