OK...just installed the V3 system to my 2000 7.3 F250. Been working with Jason and John from DFA troubleshooting this thing all week, literally every night trying something new. I'll try to list all we've done so far (no particular order):
I know I'm probably forgetting a few things. I have a pressure gage installed to the pressure test port by removing the Schrader valve. All readings are only about 25psi. When switch is in manual mode and turn the regulator all the way in, pressure does not increase. Sounds like all oil is being bypassed back into the tank.
Last thing I'm trying is just plumbing the fuel lines into a bucket (directly below the module so hoses only a couple feet long) in order to eliminate anything outside the V3 and should determine if it's the V3 itself or something in my plumbing.
If anyone has any other ideas, I'M ALL EARS and will try ANYTHING at this point! I'm determined to get this thing running...it's costing me almost $25/day with my commute to work for every day I don't get this working. I know this is an awesome system with generally few flaws, just having a few start-up issues. Also, if anyone is local to the Atlanta area and has more experience with this system, I would greatly appreciate any help.
Thanks,
Keith
- Believe all electrical is OK, pump runs, purges, engine keeps running after turning off key, etc.
- Cleaned pre-filter, was dirty, but really didn't change pressure any
- took main filter off module to see if had oil, it did, and turned to manual to see if pumping...all OK
- Removed and cleaned out fuel pressure regulator
- Jason actually sent me new pump thinking that was problem, no change, still no pressure (confirmed reinstall was correct for new pump).
- Took off fuel-in line from tank and fuel-return line to tank and blew out with compressed air in case there was obstruction in lines. No change.
Thanks,
Keith
